-   -   What would you give ? (https://www.racingjunk.com/forums/showthread.php?t=19381)
hammertime 01-02-2008 02:02 AM
I've been looking around here and there for a 454 block, 2 bolt or 4 bolt virgin to 60 over. I've found some good deals and they are gone when I get there the other ones I find seem to be more $ then I think they are worth, what do you guys think a 454 block is worth now days ?
I been looking to spend 250-300 for a 2bolt and 350-400 for 4 bolt, a year ago I found several this year nothing when I want it. am I being to cheap or are they just wanting to much ?
performanceengin 01-02-2008 04:14 AM
i haven't been lucky enough to find any b/b bare for less than $500.00 minimum. i have a 2 427 tall decks .they both need fully machined but i have $700.00 in each one.
lively 01-02-2008 04:47 AM
TTTTTTTTTTTOOOOOOOOOOOOOOOO--CHEAP---I AM AFRAID YOU GOTTA OPEN YOUR BILLFOLD A LITTLE WIDER :lol: :lol: :lol: ----GOOD LUCK ON YOUR HUNT!!!!---LIVELY
performanceengin 01-02-2008 05:28 AM
i may let 1 td block go for 600.00 you pick up in ohio. may do some trading if you'r interested.
hammertime 01-02-2008 12:33 PM
I'd really like to stay with short deck have parts for it. Looks like i better keep looking and maybe raise my limits.
tcarda 01-02-2008 04:10 PM
Around here in MN a complete Gen IV 2 bolt engine goes from 500-600 depending if it has 049 or 781 heads on it, and a 4 bolt block is around 700 plus. Good luck.
obsessedtruck 01-02-2008 04:20 PM
I got 3 short deck blocks for ya. 1 is a 100% virgin 1973 and the other is .030 and main studded. 500$ each. OR, got a bowtie block that is 4.600 needs to go to 4.630. that 1 is 700$ or cheaper it has a small battle wound which has been repaired. If you are interested give a call at 320-296-6365c all prices can change to got get ride of them. all 3 are Shortdecks...
Brian
also have a short deck 4 bolt block that is .060. rehone and that will cleanup nice.
so a total of 4 blocks for ya :D
hammertime 01-03-2008 11:49 AM
I finally came up a little on what I wanted to give and think I got a good deal from a local machine shop I use. 454 4 bolt block, bored 60 over just need finish honed. Has new cam bearing,freeze plugs and arp main cap bolts. Picked it up for $550.00 and saves me all the machine work
lively 01-03-2008 01:47 PM
THAT IS A GOOD DEAL---GLAD YOU FOUND ONE :lol: :lol: :lol:
hammertime 01-06-2008 03:17 PM
Brian
You have any 4.625 pistons laying around ?
