-   -   milky oil with toilet (https://www.racingjunk.com/forums/showthread.php?t=19358)
jim383 12-31-2007 05:56 AM
is something wrong or is this normal,everthing is new except the toilet.it seems to be putting too much fuel in the oil.it's a 388 sbc.,edelbrock alum.headed,barrel valve set at 28%,#31 jet's.#95 pill.ive not run the car yet so i don't know the egt,just got the motor done so i can crank it and let it run.i run the motor most every weekend to keep it fresh but it takes 2 gallon's of alke. to get it up to 150 weter temp.then my oil is 1/4 quart over full.the toilet had not been run in 4 yrs bofore i bought it maybe the barrel valve need's rebuilt.
OneBadGMC 12-31-2007 07:45 AM
Waaaaaaaaaaaaaaaaaaaaaaaay to rich at idle. Lean the barrel valve down a LOT.
Barrel valves have nothing except o-rings that will wear. If they dry out, you'll have fuel leaks all over the barrel valve.
hammertime 12-31-2007 12:12 PM
Dead on with that post !!
