-   -   fuel pump rod for roller (https://www.racingjunk.com/forums/showthread.php?t=19309)
olds48 12-27-2007 05:30 AM
I have a GMPP crate motor.It's a Fastburn 385.It's got a steel roller cam in it.It came with a distributor that had the bronze gear on it,my question is about the fuel pump rod for the mechanical fuel pump.Does it need to be made of a certain material(bronze?)so as to not wear out something.I can find no info anywhere,and the "tech"at the dealership I bought the engine from,didn't know what a bronze gear was.
bbchevy 12-27-2007 05:36 AM
Rod
I would also put a Bronze Tipped Fuel-Pump Pushrod in the Motor!You can get them at just about any HP Outlet?I buy alot of Parts from Comp Products in Oshkosh Wi.
Hope this Helps?
Later
G 8)
olds48 12-27-2007 06:06 AM
Cool.Thanks for info
