-   -   MSD ignition wire (https://www.racingjunk.com/forums/showthread.php?t=19266)
Superpro399z 12-20-2007 05:34 PM
MSD ignition wire
Switching from magneto to a MSD 7Al-2 ignition box. My question is how and where do I run my ignition wire off the MSD to the Painless control panel? Any help would be appreciated! Do I run it to the starter button or the ignition button on the panel! Thanks Mike :?:
gdmii 12-20-2007 10:16 PM
Run the igntion wire to the ignition switch on the panel then to a 12v source. Run a separate wire from 12v to the starter button then to the neutral safety switch on your shifter then to the starter solenoid. You can go to MSD's website and download wiring diagrams.
George
mytmouz 12-20-2007 10:42 PM
It's in here somewhere...
http://www.msdignition.com/pdf/WireDiagrams/WDTN.PDF
