Rear end problems
I have a 35 spline full floater 9", does anyone know if there is axles, centre and gears that will withstand a 2800lb Promod with a 2700hp KB, lenco drive?
I am avoiding having to go with a complete new deal. Can anyone who knows please respond. Warren |
You'll be looking and breaking several before just going to the good stuff right away. Just my 2 cents .. good luck !
Floater
If its a Full Floater,thats what we use in the Funnies and Fuel Altereds.They do Not weigh that much,but HP is there!EWhat Componente do you Have?
If you NEED any thing? Call Danny Miller @ Rear Gears 636 861 3900 Later Greg 8) |
You can go up too 40 spline axles and maybe even a 9 1/2" gear and spool, that should hold it unless you are god awful heavy.
JMO Zip. |
Hi Warren,
not sure I understand what you are asking... do you have just a housing or is it complete? 2800lbs at 2700 hp, you definatly need the good stuff. The rear end is were all the abuse happens to go through, it needs to be tuff. Not the place to save a couple of bucks in a car like that... ed |
| All times are GMT -8. The time now is 05:26 PM. |
