Bearing Clearance
When i check the oil clearance on the rod bearings with a telescoping gauge and micrometer i come up with .003 clearance.When i use plastigage i come up with .002.I think .002 is too tight but which method is right.The engine is a 620 big block chevy with steel rods.Thanks
Assuming that you are torqueing the caps on to proper torque specs i would trust the telescope gage more than the plasti-gage, although i don't use either method, i use a dial bore gage which is more accurate, but i also have gage blocks for setting the dial bore gage.
I agree that .002 is too tight for any racing motor and i usually buy .001 over bearing or polish the crank .001 under. JMO Zip. |
| All times are GMT -8. The time now is 04:49 AM. |
