sbc block freeze plugs leaks
Are there any sealers that will work on a very small leak on a freeze plug without using block sealer or removing the soft plug?
If you are looking for permanent fix, forget it. You can get rubber screw in for a temp fix, the best way is to replace it.
What is a soft plug?
I ran a SBC for 12 years and never heard of a soft plug and have been through plenty of engine projects ? Got to be a freeze plug!
I would think so also ... but maybe we are just outdated now :D
yeah i seen the rubber (temporary)plugs
pretty easy to install but dont think about using those at the track! screw in are the best. there is a pic of one here http://www.automedia.com/Replacing_a...cr20070401fp/1 I always learned to pin the plugs and use a bit of indian shellac sealer on them . |
definitley replace the plug with a brass plug and put a good coat of permatex on the backside before installation/ Just my $.02
Thanks for the info-I replaced the freeze plug and put Indian Head sealer on it.No more leak
Frost plugs are freeze plugs are soft plugs. Depends on how old you are and where you are from. Install them w/ an epoxy or JB and they wont leak. Also use brass ones and they won't ever rust through. That's important I guess if you can get a block to live a bazillion passes.
Duane |
| All times are GMT -8. The time now is 01:27 PM. |
