-   -   powerglide transbrake (https://www.racingjunk.com/forums/showthread.php?t=19173)
suicidebomb 12-11-2007 06:23 AM
Ive got a TCI powerglide with amanual valve body, andatransbrake. My problem is the transbrake wont hold in place at the line. First time it backed out after i brought the RPM up. Scared the bejesus out of me! Called TCI and they said to adjust the band, I tried that( exactly to their instructions) but it still takes off when I bring up the rpm. Im still probably doing it wrong, Imaklutz.Any help would be appreciated.
gimmemud 12-11-2007 08:09 AM
I had one do the same thing, it would move backwards when I brought the rpm up on the brake. It was low of fluid. This was a hipster brake dont know if it will help, but it cant hurt to try.
jmarksdragster 12-11-2007 08:03 PM
The band should be no tighter than 3 3/4 turns out. After that, get a pressure gauge, you should have at least 200psi. If it is backing up it is losing pressure somewhere or doesn't have enough. Low fluid level would do it, I would hope you've checked it.
us7race 12-12-2007 03:59 AM
The forward clutches could be burnt too but it would show by lots of slippage. Some of the transbrake solenoids are also adjustable too.
I think I would check the servo piston and spring then re-ajust the band, also check line pressure. Mine has 250Lbs-275Lbs with a JW pump.
suicidebomb 12-13-2007 11:33 AM
Thanks a lot guys. Ill try them all,sooner or later Ill hit on something! Even a blind pig finds an acorn once in awhile. Again, thanks.
