-   -   540 Piston questions and manufacturers (https://www.racingjunk.com/forums/showthread.php?t=19130)
tcarda 12-05-2007 10:21 AM
I am looking for a new set of pistons for my 540 to increase my compression from 12.8:1. My combination is a 4.500 bore, 4.25 stroke, with a 6.385 rod. My engine consists of a Holley 1250 dominator, ported Edelbrock Super Victor intake, Dart 355 CNC heads, and 4340 crank and rods. I want to be in the 14.5:1 to 15:1 compression ratio somewhere. Ross has a set of pistons that have a 49 cc dome, 14.5 comp .600 dome height, 1.273 ch, and a 589 grahm weight. JE also make a piston that has a 45 cc dome, 14.3 comp. 1.270 ch, and a 652 grahm weight. Which one of these pistons would work better for my motor and why, or should I use a piston?
edvancedengines 12-05-2007 11:53 AM
http://www.brcperformance.com/chevy454shortdeck.htm
http://www.brcperformance.com/chevy454flattop.htm
Or we can do anything you want in a custom piston.
Ed
gimmemud 12-05-2007 12:04 PM
You will not be dissapointed with BRC.
tcarda 12-05-2007 02:01 PM
Originally Posted by edvancedengines
Thanks Ed. I sent you a Private Message.
shawnp 12-05-2007 04:22 PM
My combination is close. Both motors bore 4.530 with 4.250 stroke. We have JE in 1 motor and just sold Wiseco out of the other. Both work great and have no problems getting them.
Pwmax 12-07-2007 05:19 AM
my advice, would be to mill the heads a bunch. You could easily get 14+:1 by doing that. That way, you save the cost of rings, bearings, hone job, the pistons, re-balancing, etc. You would be at the point of diminishing returns, by going much more than that. If you changed nothing, except bumped the compression, you won;t notice much gain anyhow. It will pick up for sure, but, if you switch pistons, I don't think you would be happy with the money per hp increase, and, more important, the gain in et. At the level your at, it takes big gains in power to do much. I pick guys up 50+hp all the time, by refining their combos, generaly, porting the heads, and, its usualy good for .2-.3 tenths, and 3-4mph. I don;t think you would even come close to those gains just from a compression increase. Thats my advice
Frank
Advanced Performance
www.get-ap.com
tcarda 12-07-2007 06:36 AM
Frank
www.get-ap.com
Thanks Frank. I am also putting in a litter bigger cam and I also upgraded my out of the box 1050 and bought a new carb from Pro Systems 1250. Also, I am adding a vacuum pump. My first thought was to angle mill the heads and tighten up the chambers from 118 to 107. But if I angle mill the heads I am wondering about piston to valve clearnance, the angle and also if I have to cut the pistons since these pistons were not made for angle milled heads. Wouldn't I have balance the assembly again if I had to cut on the pistons? The guy that built this motor originally told me that they are JE pistons with a 40 cc dome, but the pistons say SRP on them. The only SRP piston that I can find with my crank and rods says it is 12.8 w/a 36 cc dome.
