-   -   ENGINE SWAP PROB. (https://www.racingjunk.com/forums/showthread.php?t=19100)
tjwrangler82 12-02-2007 01:42 PM
ENGINE SWAP PROB.
ok i need some help i am trying to do a v8 swap in a 95 stang i have everything done except for the wiring. i have an 86 302 with the wiring harness and computer from the 86 car. i can't figure out how to wire up the altenator ignition coil and starter. for some reason i get no jusice out of the ignition switch now. and there aren't any plugs for the ignition coil and altenator because they were tied into the 86's headlight harness. but i do have the plugs that are on the coil and altenator. i also disconnected the neautral safety switch but that didnt help the starter. also will i have to hardwire the fuel pump i think i read somewhere that i have to.
one other question off the wiring topic.....what would be the best cam to getr for the 86 motor being there is not that much valve clearance? any help would be greatly appreciated...mike
