-   -   what is connecting rod side clearance (454bbc) (https://www.racingjunk.com/forums/showthread.php?t=19096)
russ67chevelle 12-02-2007 07:49 AM
my friend has a 454 bbc with an ohio crank and eagle h beam rods.what should he be getting for rod side clearance?thx for info in advance!!!russ
topsportsman1 12-02-2007 07:51 AM
I use roughly .020 for steel rods and .060 for aluminum or there abouts,JMO
pro_s10 12-02-2007 07:53 AM
so .014 would be too tight then?
topsportsman1 12-02-2007 08:08 AM
Not really if you have that I'd think it would be fine for steel rods,but just make sure you have that much in several spots in several locations on the crank,just don't check it in one spot.if its tighter you might have to get the rods machined
pro_s10 12-02-2007 08:13 AM
well its going to be street/strip motor. mostly strip. the rods are a eagle h-beam, and the crank is a cast ohio crank with stock stroke.
topsportsman1 12-02-2007 08:16 AM
Just some thing for you to feed on>
Tight means oil is going to get hotter,with that said,we all know what heat does to metal.
Every thing has to work together,oil pump,clearances,etc.rods float on the crank in an oil film,if the oil can't pass between the rods effenciently enough it going to raise oil pressure and make heat so to speak.
Thats why I gave you guide lines,at least thats what I use for a rule of thumb,
maybe some one smarter than me can explain it better :P
pro_s10 12-02-2007 08:26 AM
I just don't want to blow up a 3rd one in 2 years
pro_s10 12-02-2007 08:35 AM
this is russ' friend. this is a big block.. its a 461 with domes. 10.5:1 comp motor
Scotty2 12-02-2007 09:03 AM
How can you tell someone thats knows everything :roll:
pro_s10 12-02-2007 09:05 AM
and i see he changed some things on my account already..BACKYARD MECHANIC????WTF
