gas and alcohol
Iv`e been thinking about this for a while. Anybody mixing gas with small amounts (5-10%) of alcohol ? are there any advantages to this?
I'd have to go look, but one of the carb companies in the National Dragster is advertising a 75/25 Gas/Alcohol carb. It's a matter of getting the metering correct. 10% is probably within the jet capabilities of most Holly carbs. Also less issue with the corrosive properties of methanol and no need for top oil additive. I have considered this myself, but haven't tried it yet. Too many other irons in the fire....
Dude..............take note whats on my engine! I guess you've seen it in action before,pure alcohol is the way to. Once you've tryed it you won't go back! Close your eyes and just think,tunnel ram and enderle :D Thats about 9% extra HP all the time 8)
I'd go one way or another, alky is my choice |
gas and alky
carb guy advertising 75 -25 carbs is chuck nuytten #is 972-722-8333 i would give him a call.
Yes, I have mixed alky with gas at a 15% level back in the early/mid 90s, before moving to 100% alky.
The engine was a 462 BBC, oval port heads (049 castings), with a Crane Cam (.648/.669 solid flat tappet). 9.5:1 static compression with 8 Lbs of blower boost from a B&M Powercharger 250 (equiv of 4-71). The carb was produced from a local supplier called C&M (no longer in business to my knowledge). The carb looked pretty much like the precursor to the Holley HP line. It started as a 750 CFM Double pumped, but wound up flowing 1020 CFM after they were done with it. I really regret having sold the carb, it was a nice piece. We were running 93 octane pump gas through the motor with the 15% mix. The motor ran cooler, and we had zero issues with detonation. I don't recall how much it picked up, but I do recall a lower e.t. with the mix. It could have either been due to the decreased air charge? Who knows. I know it worked, and thats all I cared about. We tried higher percentages of alky, but the fuel separated too much. |
Re: gas and alcohol
I'm with Nofear...inject it .
Is there really a power advantage to swapping to alky,all other things remaining the same?
| All times are GMT -8. The time now is 05:26 PM. |
