Super Victor 2925- Any good?
Trying to find a taller manifold to get my scoop sticking out of the hood. Dont just want to use a spacer. How is the Victor 2925? Will it work with my Brodix track 1's? I know i will lose bottom end over the Brodix 1016 i am using now, but anything else i should know?
How mych more performance do you get if i have it Ported & Polished before i put it on? (if i put it on) |
The Super Victor is a great manifold, what is the rest of your combo and RPM range? Converter stall to trap RPM.
My stall is a 2000 stall i belive. My engine is a 408 sbc with brodix track 1's and a comp cams 244-600 cam
Match the intake ports to the head and clean up any rough areas inside. You may gain with up to 2" spacer on the Super Victor as well. You need more stall. If you have [email protected] you need 4500 to 5000 (9" would get you there) to get the car to launch well. Big gains there, buy from a name company. Give them ALL the specs on your car and engine.
| All times are GMT -8. The time now is 01:54 PM. |
