-   -   what will make a car not get spark (https://www.racingjunk.com/forums/showthread.php?t=18867)
shutupracer01 11-11-2007 04:40 PM
i have a 1995 handa accord i was drivin it and i shut it off and now it cranks but the spark plugs ant sparkin what can it be emale me at
*EDIT* Spammer
hammertime 11-11-2007 05:05 PM
Coil, Plugs wires, Ignition are basics
davis419b 11-11-2007 05:13 PM
Hammertime, im not sure i would send a return message by e-mail. This is a yahoo address and not a very good speller. I could be wrong.JMO
hammertime 11-11-2007 05:15 PM
Originally Posted by davis419b
Hammertime, im not sure i would send a return message by e-mail. This is a yahoo address and not a very go speller. I could be wrong.JMO
I figured if he wanted to know what he thought he'd get back on here :D
zipper06 11-11-2007 05:32 PM
You guys are both right on, who needs spam mail.
8)
dart441 11-12-2007 02:10 AM
Quite frequently, with Honda it is the coil in the distributor. Easy fix.
bjuice 11-12-2007 04:58 AM
Re: what will make a car not get spark
Guys please re-read this post..the man claims his car will "CRANK"but the plugs are not firing....this is IMPOSSIBLE.....the plugs have to fire in order for the car to crank..I consider cranking the same thing as starting/running....Now unless i have missed something with imports..i still think the 3 basics apply to an engine cranking /running..
1- fuel
2- fire
3- air
will not run without all 3 present ..at least the engines i deal with anyhway.
maybe he thinks a motor spinning over is considered cranking..i don't know....
Brian
davis419b 11-12-2007 05:27 AM
Bjuice ... The point is why not wait for you to reply here rather than ask you to e-mail him an asnwer. he wants your e-mail address!
dart441 11-12-2007 05:42 AM
Must be a difference in how we say things in different parts of the states. Up here in Michigan most of us consider cranking as the starter is turning the engine over, but engine not running. Same as "spinning it over".
Duane
AND I wouldn't send an e-mail either. If they post here, they should check for an answer here.
bjuice 11-12-2007 05:48 AM
uhhh ok ..yeah i saw that "i do not personally e-mail unless i know you)..i was just reading some replys and got confused on the terminology..."cranking" vs "starting"...
in the South if your cranking it your in business...same with starting..
i guess i DO NOT get the spam e-mail thing..when i get on-line its on a racing forum thats about it...
later.
Brian
