-   -   O-RING ON CYL HEADS (https://www.racingjunk.com/forums/showthread.php?t=18856)
RSM 11-10-2007 05:41 PM
O-RING ON CYL HEADS
I AM BUYING SOME HEADS THAT ARE O-RINGED, WILL THIS BE A PROBLEM ON A BLOCK THAT IS NOT O-RINGED OR DOES THE BLOCK NEED TO BE O-RINGED ALSO TO MATCH. CAN THE O-RING BE WELDED UP ON HEAD THEN MACHINED DOWN.
a13badazztoys 11-19-2007 03:49 PM
Are the heads aluminium?? :?:
