-   -   anyone got a desktop dyno? (https://www.racingjunk.com/forums/showthread.php?t=18846)
rabiddawg 11-09-2007 03:41 PM
someone plz run a virtual dyno on my setup
406 cu inch smallblock
12:1 compression
titanium rods
6800 rpm (should go more but this is a safe RPM)
cam specs:
290 intake/290 exhaust
adv duration @.050
222intake/222 exhaust
valve lift .477 intake/.477 exhaust
lobe c/l 114
1:6 roller rockers
stud girdle
brodix spec heads part number (SPCH)
head specs:
215 cc intake ports
2.080 intake valves
1.60 exhaust valves
super victor intake (single plane)
3600 pound car
190 pound driver
3:73 rear gear ratio
TH 350
3000 stall converter
27.0 inch tall tires
12 inch wide
badrad 11-10-2007 12:18 PM
I ran that same cam in a 10:1 406 SBC and it flat hauled, have fun.
curtisreed 11-10-2007 01:59 PM
I have to ask, why are you going to run titanium rods in a motor you are looking to run a "safe" rpm? Also if you want someone to run a drag program you need to include tranny choice.
Curtis
rabiddawg 11-10-2007 02:39 PM
opps ok I fixed it
car has a TH350
the engine came with the rods so ill use em.
I figured 65000-6800 would be a good starting point because all I know about the motor is that its a modified IMOD motor.
still has the original cam which they are restricted to use .
its good to hear someone else ran that cam in a 406 I was kinda concered that it was pretty small.
zipper06 11-10-2007 06:44 PM
Man the rods are worth more than the engine, wanna trade them for some good H beams. Hehe JK :lol:
rabiddawg 11-11-2007 02:28 PM
yeah even though the effective range of the cam is below what the rest of the rotating assy can handle I was gonna use it anyhow for the street.
that why I wanted to see what the motor will put out.
ProStreet427TT 11-24-2007 10:35 AM
Just my opinion here mate... over here we'd never put a cam which is as small as the one you've listed into a motor of that size, even for full street use. I'd be heading towards 0.550" lift at least with a 112 l/c minimum (probably a 110 l/c) & 246 @ .050". That is a baby cam which will idle real smoothe.
Even my road car which has a baby 310ci V8 in it has 0.555" at the valve with 1.65 rollers, 108 l/c & 248 @ .050".
The cam just seems way too small to me. :)
rabiddawg 11-24-2007 11:33 AM
yeah I know its being changed now but I wanted to see the numbers once I found out what cam is in there.
I got an ISKY roller cam and durathon roller lifters on the way
Brand: Isky Racing Cams
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 3,000-7,000
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 238 int./248 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 294
Advertised Duration: 284 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.578 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.608 in.
Valve Lift with Factory Rocker Arm Ratio: 0.578 int./0.608 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: RR-284/294
that should wake up that motor.
