-   -   rear disc brakes (https://www.racingjunk.com/forums/showthread.php?t=18841)
gasalley 11-08-2007 12:22 PM
rear disc brakes
:?: does anyone know of an economy set up for rear disc brakes on a 9" Ford rear end? I have a `66 Bronco axle that I want to put in my `47 Ford Coupe. I don't have any brakes now. The Bronco has a 5x51/2 bolt circle,
any help would be appreciated. thanks!
Racefab57 11-09-2007 07:04 AM
Strange has a cheap disc setup Ive used on strip/street cars. its actually uses bronco rear disc's, has an emergency brake setup, and is reasonable, try em.David.
gasalley 11-15-2007 03:13 PM
re
thanks for the info. I will look into that set up.
tylera189 11-20-2007 03:48 PM
Also check checkeredracing.com they have a setup for stock axles. also check speedwaymotors.com they have a setup that uses stock gm calipers. also designed for stock axles
gasalley 12-03-2007 03:51 PM
thanks for the help. I will be checking these out.
