survey on carb spacer
Please submit spacer brand, hieght, small block or big block and dyno results if you have them thanks
http://www.apdracing.com/carbaccessories.cfm
this carb spacer is bad to the bone !! I've seen from .02 1mph to .06 & 2mph Not sure about dyno #'s I dont race a dyno or its sometimes false #'s :D |
hvh supersucker
below was copied from HVH Supersucker website As Seen in Car Craft, Dirt Late Model, Late Model Racer, Camaro Performers, and Super Chevy! Read National Dragster article on the HVH Super Suckers Super sucker carburetor spacers are the most effective carburetor spacers ever developed. Adds up to 47 HP naturally aspirated, and 500 HP with nitrous oxide Super Sucker carb spacer also properly distribute the air/fuel mixture to the manifold. Improvements in the throttle response, driveability, top end horsepower and torque are commonplace when using a Super Sucker. Part# Description Plastic LW Alum Aluminum SS4150-1 1" tall composite Super Sucker spacers for 4150 series carburetors $88.00 $121.00 $112.00 SS4150-2 2" tall Super Sucker spacer for 4150 series carburetors $112.00 $144.00 $131.00 ST4150-2 1” tall Street Sweeper Spacer for 4150 series carburetors. Fits Performer and Stealth manifolds N/A N/A $112.00 ST4150-4 1” tall Street Sweeper on dual plane intakes. Fits Performer RPM, Brodix HV 1016, Dart Kool Kan, and RPM Air Gap manifolds N/A N/A $112.00 SS4500-1 1" tall Super Sucker spacer for 4500 series carburetors $88.00 N/A $112.00 SS4500-2 2" tall Super Sucker spacer for 4500 series carburetors $105.00 N/A $125.00 SS4500-1.1 1" tall Super Sucker spacer for 1250cfm carburetors with 2.125 bore $88.00 N/A $112.00 SS4500-2.1 2" tall Super Sucker spacer for 1250cfm carburetors with 2.125 bore $112.00 N/A $131.00 SS4500-C 1” tall Super Suckerä Spacer for cloverleaf manifolds $88.00 N/A $112.00 SS4500-2C 2 ” tall Super Suckerä Spacer for cloverleaf manifolds $112.00 N/A $131.00 SS4412-0 1” tall Super Suckerä Spacer for 4412 series carburetors, open hole design N/A N/A $105.00 SS4412-2 1” tall Super Suckerä Spacer for 4412 series carburetors, two hole design N/A N/A $112.00 SS4412-1 SWAL 1” tall Super Suckerä Spacer for 4412 series carburetors, sideways mount with two hole design N/A N/A $112.00 SSTBI 1” tall Super Sucker Spacer for GM throttle body N/A N/A $79.00 SS4500/4150-2 2” tall Super Sucker Spacerä adapter for 4500 series carb to 4150 manifold N/A N/A $149.00 *Plastic is for Drag Race Only. *Aluminum is for street-strip or oval track applications. Call for availability on all part numbers W/D buy-in $2,500.00 initial minimum purchase Prices are subject to change without notice Designed by Joe Petelle at HVH over 15 years ago for Winston Cup engines, this spacer will increase air speed from the base of the carburetor to the top of the intake valve, pulling more fuel from the carburetor, the Super Sucker will require a change in the size jet currently being used. E.T. is reduced as much as 1/10 of a second and lap times reduced as much as 2/10 of a second. Super Sucker are made from two different materials- aluminum and high temp composite HVH composite Super Sucker spacers are CNC machined on Haas vertical milling machine The composite spacers offers a thermal brake from the manifold to the carburetor Keeping the carburetor cool also allows cooler air to enter the manifold which results in more horsepower |
| All times are GMT -8. The time now is 01:32 AM. |
