-   -   Difference between Holley standard bowls and marine bowls (https://www.racingjunk.com/forums/showthread.php?t=18821)
davezilla 11-06-2007 05:45 PM
I need to know if anyone knows for sure if the rear fuel bowl that fits a Holley 830DP is the same fuel bowl that fits a Marine 850DP.. Marine fuel bowl part number is 134-102. I have a bent inlet on my 830DP bowl and I was sent this marine bowl as a replacement. Will it work properly? Thanks
cepx111 11-07-2007 02:42 AM
Here's what I came up with, that part number is for:
P/N 134-102
Replacement Fuel Bowl Kit-
Secondary, center-hung w/ fuel inlet provision.
Standard finish
If yours has a rear accelerator pump which I believe your does you dont have the right one.
This is the correct secoundary replacement bowl for a double pumper:
P/N 134-104
Secondary, center-hung w/ provision for accelerator
pump and fuel inlet. Standard finish
Hope this helps.
Goodluck, Charles
davezilla 11-07-2007 04:39 PM
Fuel bowls
Thank you for your help. David
