-   -   Pinion angle question (https://www.racingjunk.com/forums/showthread.php?t=18743)
roadruner150 10-27-2007 07:33 PM
Can i set my pinion angle by putting a spacer between tranny and crossmember? Or do i have to adjust the rear end? Tranny is solid mounted.
us7race 10-28-2007 12:19 PM
Has to be done with the rearend to adjust Pinion angle. Pinion angle in itself is a direct relationship with the Pinion Gear since the yoke is attached to it. The driveline angle would be effected if you put a shim under the trans mount. What kind of setup are you running?
roadruner150 10-28-2007 02:31 PM
Ladder bars is whats on it. Can i adjust front holes? Or back of ladder bars? Looks like back is gonna turn about 3 or 4 turns till bottomed out.
edvancedengines 10-28-2007 03:32 PM
Roadrunner,
Are there not any threaded adjusters on the rear of your ladder bars? I do not know of any that can not be adjusted some for pinion angle adjusting?
Before you fight with adjusting the angles, just what is your current pinion angle in relation to you driveshaft angle? Does the driveshaft angle up as it goes forward from the rear yoke and U-joints?
Also do you have leaf springs or something different?
Ed
roadruner150 10-28-2007 07:34 PM
I just spent tonight lowering front of ladder bars. Before i had zero angle on very back of driveshaft. Now it looks like i have 2 degrees of angle just moving bars on hole down. I have adjustable shocks in regards of question. Is this enough angle? I cant tell until morning when i start car and drive it to see if vibs are gone. But zero angle is not good, i know that much, hopefully no more twisted driveshafts for me.
us7race 10-29-2007 02:21 AM
I run a ladder bar setup with coilovers and run 1.5 degrees of Positive pinion angle to get my driveline angle right. If you have Leaf springs then more negetive is required to keep it at or around 0 under load.
With the ladder bars and Coil Overs the rear suspension don't move much.
roadruner150 10-29-2007 06:09 AM
Thats my set up also! I have five holes on front of bars, it was up on top holes and zero angle. Last night i moved them down a hole and got 2 degrees of angle. Still have yet to run car this morning to see if vibs are gone. Hopefully sway bar doesnt need to be adjusted moving everything last night.
roadruner150 10-29-2007 08:41 AM
Well car still vibrates. At about 35 to 45 it vibrates then it goes away. I just had new driveshaft made , thinking its not balanced right. Gonna take it back to be rebalanced today,,,, GEEEZZ :evil:
Bubstr 10-29-2007 09:42 AM
The solid mount on the tranny could be your vibration problem. Not so much problem as transmitting what vibration you have. I like solid engine mounts but trannys should have some give.
2 to 5 degrees is good threw the movement of the rear, but if you moved the front of the ladder bar, you have changed your instant center. If you adjust on the rear of the bars, it will keep the same I/C if you adjust both the same.
When looking for a vibration, I jack rear up and first check for loose u joint or sloppy tail shaft or pinion bearing. Then remove wheels and tires, if you have drums a couple washers and the nuts back on and run it. Still have it, get a chalk or grease pencil tape it to a yard stick and prop it on a short jack stand and move it slowly towards the drive shaft, front and back. This will give you a rough idea where it is. Don't forget a bent or twisted axle can do this too.
