-   -   Advice on Cylinder Heads (https://www.racingjunk.com/forums/showthread.php?t=18735)
RaceReadyRacing 10-27-2007 08:20 AM
I looking for some advice on which cylinder heads to run or if I already have the correct one's or not. The car is a street/strip car that see more "streetracing" than track time. I only go to the track once or twice a year. The specs are below...
Engine:
GM Block 496cu. in. (4.31x4.25)
6.385 Rods
JE SRP 8.5:1 Pistons (135psi cranking)
Cam is a solid roller 255/262@50 .653/.653 114
Pro 1 325 Heads
Jesel shaftmounts
Dart 4150 Rec. Intake
C&S 900cfm Blow-thru carb
Procharger F2 (17psi)
Non-Intercooled
Headers are 2 3/8" Primaries / 4" Collector
Exhaust will either be 3 1/2" or 4"
C16 racing gas
Car:
1973 Camaro
3500lbs. with driver
4.88 gears
33x18.5x15 ET Streets
TH400 Trans
9" Converter 4500 Stall
davebat 10-27-2007 09:49 AM
I don't know about the heads but wondering why you are burning C16? I would think unless your running Nitrous, C12 would be fine for your compression and boost. What do your plugs look like at the end of the day?
Are you just being xtra careful about detonation?
RaceReadyRacing 10-27-2007 10:00 AM
I'm probably just being extra careful. I have run both C12 & 110 Sunoco with no problems. Never really looked at the plugs because I have an LM-1 which always reads around 11.5 WOT
hammertime 10-27-2007 10:35 AM
I agree on the on the C16 Over Kill, 110 is plenty.
Them heads are not bad heads at all, I've seen them used on 555's with some port work and work just as good as some Dart 355's.
elkymann 10-28-2007 05:53 AM
fuel rating/heads
I'm with Hammertime here also, those heads flow plenty for your cuin. just cut back on the fuel rating and hang them hoops. You may want to read your plugs after a hard race sometime, just cut the engine off and coast and bring your plug tools, pull a couple and see what they look like, obviously they should be a nice gray color and dry if all is well. Good luck with your combo. :D
Elkyman
RaceReadyRacing 10-29-2007 03:45 PM
Thanks guys, my only concern about the heads was because of the procharger & 17psi. I see alot of procharged 540's with 355 heads so I wasn't sure if I should have gone with 355's or 345's. Do you guy's think the next time I rip the engine down I should change them to the bigger head or stay with what I have?
kwillymac 10-29-2007 05:07 PM
Just make sure you don't use too much octane...lol.
firestone 11-05-2007 09:55 AM
If anything, when you tear it down, get a good port job on the heads you have now. That will open them up a little, but the port work should really pick things up.
Adam
