-   -   Brodix intake has holes in four sides, what for? (https://www.racingjunk.com/forums/showthread.php?t=18705)
Blue68Camaro 10-22-2007 08:20 PM
So i am used to plain old edelbrock manifolds. What are the water ports for on the top on the manifold. Can i just plug them? Should i just plug them or??
cepx111 10-22-2007 10:33 PM
Some people run a bypass from the front to the rear to equalize water temps across the cylinder head and prevent hot spots.
I've always just plugged them and never had any problems. But then again all those exta fittings and hoses all over the top of the engine looks pretty cool.
Here 's alink to a simialr thread about the same question on yellowbullet
http://www.yellowbullet.com/forum/sh...d.php?p=288725
Hope this helps.
Goodluck, Charles
hammertime 10-22-2007 10:39 PM
I've always just plugged mine
Blue68Camaro 10-23-2007 05:20 PM
Thanks, i think i will plug mine too.
edvancedengines 10-23-2007 06:58 PM
I have always just plugged them but you can benefit from them if you have hot spots. Run a piece of small dia tubing from them forward of the thermastat housing or return outlet and join them to the return line like in a water manifold or an accessory filler neck and they will vent air to the return and help give more even cylinder cooling.
Ed
