Race gas vs. Methanol vs. Ethanol
We have almost finished our new SBC, it is 12.5 to 1 compression, Brodix alum heads, Herbert roller cam 0.6 lift. It has a 3500 stall, TH 350 with 4.11 gears. Car is about 3200 lbs.
One thing we don't have yet is a new carb. I plan to install a whole new fuel system, tank to carb. Some guys at our local track says I should run methanol instead of race gas, easier to get a little cheaper. I was also thinking Ethanol. Anyone know the differences in using these three fuels? I don't see many running Ethanol, but I do hear of it. thanks for your help. |
check out e85carbs.com in minnesota this guy has some info he is building carbs for it he says fuel system has to be 25% larger than if you were using 91 octane i am thnking of switching my supercharger motor over to it i am looking for more info to
Fuel mixture
what would u say about a car that runs on 40% methonal & 60% Arco regular gas? the car runs 8.80@154mph, 2820#car with 582 ci. powerglide, 5.86 gears. have been doing this 4 over 30 yrs. (fuel)
Re: Fuel mixture
Zip. |
Re: Race gas vs. Methanol vs. Ethanol
One thing we don't have yet is a new carb. I plan to install a whole new fuel system, tank to carb. Some guys at our local track says I should run methanol instead of race gas, easier to get a little cheaper. I was also thinking Ethanol. Anyone know the differences in using these three fuels? I don't see many running Ethanol, but I do hear of it. thanks for your help. www.apdracing.com Complete fuel systems and awesome stuff !! |
Stick with a real carb shop for an e-85 carb, vs the e85 carbs.com place, trust me. As far as that 8.80 at 154 with 5.86 gears, at 2820lbs, that thing must be spinning close to 9500 in the lights, wow.
| All times are GMT -8. The time now is 02:01 AM. |
