-   -   Converter ID? (https://www.racingjunk.com/forums/showthread.php?t=18622)
bbchevy 10-12-2007 01:51 PM
Converter ID?
I have Purchased a 10"Converter from a Fella on the West Coast.He has said that this Converter is a CONTINNENTIAL Brand?Although,i have NOT been able to find any Markings indicating that?It does have 4,1/2"x1 1/2"Metal strips,with the #15 on them?that i'm guessing are Balance weight's?It does have the 6 Bolt Flange with the Heavy Ring.Painted Gloss Black.
He Claims it was the Twin to another Coverter that came from Contennential?
The application!Blown Alky 500" BBC,Glide with a Turbo Spline.
Any Help,or thoughts?
THANKS
Later
Greg 8)
[email protected]
lookingaround 10-12-2007 01:57 PM
i had one back years ago that sounds just like that it was a GER though. took 6 bolts to bolt it to the flywheel. that sucked
topsportsman1 10-12-2007 02:00 PM
Greg you might be able to email them and they can tell you just what it is.
http://www.ctconverters.com/html/race_converters.html
Tod74 10-12-2007 03:25 PM
I don't think I would ever buy a used converter unless it was a good friends that bought it new and I knew just exactly what it was...but maybe I am paranoid.The odds it is right for your combination would be slim,in my opinion.
bbchevy 10-13-2007 05:51 AM
Converter
He has ran almost the Exact Combo that i run Now!
BBC 526 Rodeck Akly Inj.14-71.
He did go a Fairly Desent 6.90 @ 200mph.Which is OK?
He has now switshed to a Blown Hemi with a B&J 3-Speed,so theres were the Converter has came from!
As for the 6-bolt mounting Flange,when you step up to a combo like this?Those few Extra Bolt are NESSesary,to couple the Power to the Trans!
THANKS
Later
G 8)
