Looking for opinions here
Getting ready to send my Enderle hat injection out to be flowed and set up for my engine changes for moving to methanol. I have trust in the shop doing the fuel system.
I will be having a custom grind solid roller cam done, I have trust in the cam grinder. Fuel guy would like specs on the cam for setting flow and bypasses. Cam guy says anyone asking for this info for setting up mechanical injection does not understand engines. I have not informed fuel guy of cam guys comment. I have my opinion. What's yours? |
When you say FUEL GUY..do you mean the man setting you your injection?..clear me up here.
Brian |
My opinion....
My opinion is that your cam & fuel guys do what they do because they're very good at it. Your cam guy knows cams. Your fuel guy knows fuel systems. Give your fuel guy the information he wants. He may or may not actually NEED it, but if he feels he does........just my opinion
Could be the fuel guy knows something the cam guy doesn't. :wink:
ok i figured it out on my own...Yes the info he is requesting can be used in properly setting up your injection...and the cam profile will make a world of difference how you fuel burns off.
there will be several areas your injection guy will deal with 1- Main jet 2- Nozzels 3- Barrell valve which is set up with a leakdown testor 4- feeler gage for the proper specs in setting the injector blades 5- if your running a high speed-bypass he will have to place the proper shims in that check valve fom one injectionn guy to the other..i feel you cam guy doesn't know his injections from a hole in the wall.. my 2 cents...sorry for the brain fart on my last post. Brian |
Brian I have never worked with either of these guys before but they are both highly regarded in their respective fields and both come highly recommended. Cam guy won't cut loose details on the cam until order is actually placed and I won't be dropping the cam order for more than a month. I want to get the fuel system done this month as his busy season starts in December - January and I would like to beat the rush. Bit of a quandry, no? Murff |
Please keep Jim at ENDERLE INJECTION in mind if you get this thing and have problems..Jim is the man and can get you very close just by a phone call..trust me here MURFF...He worked wonders for me.
Brian |
Murff
The cam guy most likely don't know what he's doing,I'd get another cam guy myself,the injection guy,I think I know who he is,am I correct? PM me the cam guy I hope its not who I think it is. |
Well that is a pickle! I guess you could see if the cam guy would allow you to place the order and give him credit card info, and get the specs with the understanding that you won't expect to recieve the cam or the charge until next month......or find another cam guy that isn't so secretive
I just thought I would try going with one of the 'name' grinders this time. The derogatory nature of the response that I got from cam guy when asking for him to talk to fuel guy leaves a pretty bad taste. As was recently pointed out to me, it's my money and I can spend it how and with whomever I please. I need all of my components to play nice with each other in my engine. Shouldn't be too much to ask the same of my vendors. Murff |
| All times are GMT -8. The time now is 06:26 PM. |
