496 Heads
I am putting a spare motor together and need a set of heads
Parts are as followed 496CI Stock 4 bolt block Eagle crank & rods with upgraded bolts Weisco 14:1 pistons Comp Cam 775/725 284/292 in @ 108 454R intake Rons Terminator Injection What heads would you use ? Keep budget in mind here I hope to never use it being a back up. Anyone ever used these ? http://www.racingjunk.com/post/83881...ASSEMBLED.html |
Those sound like some happy flow numbers but for a motor you don't plan on running it doesn't seem like a bad deal.
George |
George But my theory is you pay for what you get.I think it would be a great investment for something you would hope not to run :P Things I have learned in the racing business,in the last 30 years,trying to save a buck here and there has cost me over double some times. So with that said,I'd buy a good product once and not end up putting a bunch more money into some thing you'd only have to upgrade alot of the parts that they us to assemble some of these "good deals" Buy american products and keep america working.Maybe after all the american shops shut down,you can go work and race in china :P |
IMHO I wouldn't use those heads. They are known for being poor craftsmanship AND a dealer of those heads said that those flow numbers are VERY inflated. For less money buy a pair of Summit(Made by Dart) iron heads, with a little port work they flow really well. Here is an article using them,http://images.popularhotrodding.com/...+flow_test.jpg. Good luck
Re: 496 Heads
Parts are as followed 496CI Stock 4 bolt block Eagle crank & rods with upgraded bolts Weisco 14:1 pistons Comp Cam 775/725 284/292 in @ 108 454R intake Rons Terminator Injection What heads would you use ? Keep budget in mind here I hope to never use it being a back up. Anyone ever used these ? http://www.racingjunk.com/post/83881...cc-ALUM-HEADS- PORTED-ASSEMBLED.html I have a Nice Very Few Run set of Brodix BB-X's Ad #976892.Same old Deal they were Sold!Only PROBLEM,the MONEY Never made it here??? I would let you have these for the Original Price.I'm Not that far from you,and if your Interested we could Meet in the Middle somwhere and you could Look Them Over? THANKS Greg 8) |
The CnC work looks like junk to me but worse then that is those head
castings that are made in China are JUNK !!!!!!!!!!!! They will be good for a spare motor to hold the manifold in place, .. just swap on some good heads before you actually START the engine, .. It's getting really old, I keep posting that these things crack, .. studs pull out, .. and I've seen the seats fall out and on a new set here the seats weren't even in all the way, .. Junk is junk simple, . if it's too cheap to be true, .. it's junk, .. Buy an iron Dart and you'll be miles ahead of the game with a head that will run much better and not crack, .. Curtis |
Curtis you crack me up LMAO,
First of all i'm a procomp dealer, and the add is an outright lie. Direct Motion in Ca. does the CNC porting of these heads for procomp. They are in fact 320 cc runner heads as cast and the most flow that DM has been able to get is 373 cfm. ProComp does not make a 360cc runner head. the spring pressuse will not allow you to run a solid roller cam. Hammer save your money, unless you think you have to have these heads i'll sell them to you cheaper, but the warrenty is invalid right after you open the shipping box. Zip. |
Zip. can you tell, as a cylinder head guy, .. I'm getting really tired of talking about these junk heads, . . buy based on price, .. you get what you pay for, .. .. it's like the laws of physics, .. it can't be changed, .. good stuff costs money, .. junk it cheap, .. what part of this is hard to understand? Ok Zip, .. now get up off the floor and stop laughing. :lol: Curtis |
Hey Curtis, i'm done :lol:
You have any solid s/blk heads 23* for my blown s/blk, if not what would you recommend 383" 1471 littlefied stripped 30 PSI, with buzzard catcher. 2 1/4" zoomies. Thanks in advance, Zip. |
You have any solid s/blk heads 23* for my blown s/blk, if not what would you recommend 383" 1471 littlefied stripped 30 PSI, with buzzard catcher. 2 1/4" zoomies. Thanks in advance, Zip. I tend to use Dart castings for blown stuff, .. for a small block they make a 220 casting in their race series with spread exhaust ports. Gotta use the spread exhaust and run water between the the center two ports, .. I'd have to ask if they make a solid version of it, . Curtis |
| All times are GMT -8. The time now is 04:47 AM. |
