check this Diesel daily driver out!!!!
http://www.youtube.com/watch?v=fiiFRdIjbi8
more vids can be seen at www.ngmdiesel.com 04' Common rail dodge cummins 2500 cc sb 4x4 race weight--7100lbs single charger stock internals stock head just a little bit of NOS and proper tuning!!! 8) |
I like that!
It will be for sale as soon as we get her in the 10's.......
a 6pt roll bar is being installed as we speak. Hopefully we will set another record this weekend. 10.XX would be very sweet!!!! thanks |
How much propane are you useing?, No matter it's impressive
Zip. |
im only useing 2 stages of nos, and each jet is very small about a .070 pill 8)
I gotta say that i'm impressed, with that weight running that quick. There's some guys around Memphis useing propane injection, but they are no where close to what you're running.
do you realise if you put that engine in 2500lbs it would run 8's ? Zip. |
well accually were building the same motor and putting it in a 4-5k truck, so the 2500lbs+ drop should get us in the 9's........
if i had a 2500lbs truck thats exactly were it would go!!! this truck will be going after we make 10's for around $55k then we are fully focused on the next project, our pro street truck! |
I got a 1998 Sonoma shortbed stepside , back halfed with 9", rack and pinion,and cage, absolutely clean beautiful truck not a ding dent or scratch you could drop it right and be ready to go, if you haven't already started one.
Zip. |
i have a 95 ram 1500 that a diesel is going into for pro street...............but a pro mod diesel would be sweet!!!!!
only i need to sell the truck in the video first, then we could talk.... |
| All times are GMT -8. The time now is 06:37 AM. |
