-   -   Big Block Chevy Help (https://www.racingjunk.com/forums/showthread.php?t=18276)
badluv 09-03-2007 04:48 PM
:?: I have a 1998 gen 6 454 block,how big can it safely be bored to.If you turn the block upside down and look at the bottom of the lifter valley it has 7.4/8.0L does this mean it could have been used for a 502.Thanks
edvancedengines 09-03-2007 06:58 PM
That is possibly correct.
Do you have the full casting number of the block?
The gen 5 502 was only good for 700-750 hp.
Ed
SVRE 09-03-2007 08:09 PM
I have a gen 6 block 566 making 985hp with 4.605 bore. So far so good.
edvancedengines 09-03-2007 10:37 PM
I believe your name is Steve, according to your signiture?
If the block is a Gen 5 or Gen 6 BowTie it is very strong. I wouldn't be scared to put 2,000 hp in either one. It is the standard 502 cu in block that is weak in the main webbing but it will bore bigger. GM recommends to to go 700 hp . I consider this to have a safety factor included though. I do know of them doing more hp.
Ed
SVRE 09-05-2007 06:19 PM
Ed
Yes my name is Steve.
The 566 I built was for a guy in WV who had to run a "stock block" class. Then 2 weeks after we finished it, they changed the rules to allow aftermarket blocks. Go figure...
This off season we are going dart.
