-   -   Hoosier QTP 29x11.5 (https://www.racingjunk.com/forums/showthread.php?t=18236)
Rick121 08-30-2007 04:44 PM
Hoosier QTP 29x11.5
Do these tires need tubes in them?Also what kind of air pressure would be a good starting point in a all stock suspension nova with slide a links and a small block?.Thanks for any help.
us7race 09-12-2007 04:03 AM
I run Hoosier Quick Time Pro tires and do not use tubes, never have.
I have ran as much as 13 Lbs and as low as 6.5Lbs..I'd start around 10.5 Lbs and go from there. Got to check them after they cool down not right after a pass because they will vary when heated up..I think they go up about a pound from cold to hot.
spib 09-12-2007 08:10 AM
I use these also 29x14.5 I run tubes and they are screwed down. jody is a lot faster and doesnt so it looks like both ways will work. I also run 10lbs and like these slicks alot
