-   -   850 and 950 carb ? (https://www.racingjunk.com/forums/showthread.php?t=18126)
nabit 08-18-2007 06:13 PM
850 and 950 carb ?
I have an 850 holley 4150 right now and I want a 950. I see that you can get the main body to make an 850 a 950 but I am not sure if they use the same base plate. Some places list the base plate as a 850/950 plate and others list them separate.
Do the 850 and the 950 4150 holley carbs share the same base plate or not?
also if the plates are the same is this just a simple bolt together thing with changing out the main body or what is all involved?
Thanks!!
nabit 08-19-2007 09:29 AM
no one knows?
mytmouz 08-19-2007 01:05 PM
I'm pretty sure the 950 uses a 850 baseplate.
nabit 08-21-2007 02:28 AM
thanks!!
blue66 09-04-2007 09:21 AM
To make a 850 into a 950 you would have to put a 750 main body on the 850 base. A HP 950 is smaller than a convential 850.
750 carb, w/ a 850 base plate = 950
confused yet?
Tod74 09-29-2007 03:33 PM
confused yet?
yes :shock:
cepx111 10-01-2007 11:23 PM
Look at it this way....
If you speed the air ^ UP ^ you can get < MORE > air thru a smaller hole.
Its all about velocity.
Cp
