ALKY Oil,somewhere in mid MICHIGAN?
Getting ready to Lite the BBC on ALKY?
Heres the Question? I'm Located just south of Manistee,Michigan. Where and what kind of Oil are you Guys using in your Injected Alky Motors?And,how about a Distributor?As far as someplace to buy the OIL? If any of you Guys have a surplus of Oil,and would SELL a few cases?That would be Great!!! THANKS Greg [email protected] 231 690 5075 Cell 8) |
You have a PM
thanks Brian |
valvoline 20/50 racing oil
Valvoline 20-50 conventional racing oil (not VR1). Jegs sells it but NAPA will sell it to you for about $1.00 to $2.00 less per quart. They don't stock it but is a cataloged item and they can have it overnight.
Lucas 20/50 and 1 quart of lucas oil stabilizer ,I change my oil in my Blown SBC about every 5-6 runs and I use a WIX filter,I have very good luck using this oil and filter,Hope this helps!
OIL
THANKS for your Replys!!!
I will be going with Brad Penn 20-50W and or 50w.I have found a Dealer in Dorr,Mi. As far as a Filter,WIX are the Best by FAR!!I do have a System 1 set-up that will go on the Chassis this Winter.But,until then the Wix Filters will be in place! THANKS AGAIN! Greg Reed Fountain,Michigan 8) |
Wix and NAPA are the same filters, Wix makes NAPA filters.
Zip. |
and Valvoline makes napa oil ..
AND: the Wix racing filter you get from NAPA don't even say NAPA nor are they in NAPA box. They are the same box/filter that is Wix everywhere else
| All times are GMT -8. The time now is 01:34 AM. |
