-   -   what is a air pan good (https://www.racingjunk.com/forums/showthread.php?t=17956)
Timmyboy86 07-29-2007 07:13 AM
why would anyone want a air pan i looks like it would trap more hot air than its worth?
cepx111 07-29-2007 05:47 PM
need more info ? what are you refering too. a carb air pan?
Timmyboy86 07-30-2007 02:08 AM
yes
Timmyboy86 07-30-2007 02:13 AM
http://i190.photobucket.com/albums/z.../011507039.jpg
curtisreed 07-30-2007 03:39 AM
Think of it as a poor man's forced induction.
Curtis
billhendren 07-30-2007 05:11 AM
If you have a 500 H.P. engine and you raise the carb inlet temp 100 deg you loose 50 H.P. thats why you don't want ANY under hood air in the carb.Bill
hotrod1024 07-30-2007 09:52 AM
Air pan
Heres mine.Not pretty but functions excellent.When hood is on seals great.[img]http://i200.photobucket.com/albums/a...ust7Medium.jpg[/img]
Timmyboy86 07-30-2007 01:44 PM
should you still run a air cleaner then? i was gonna run one of those bouble top air cleaners to help air get to the carb. well why not just bolt it between the intake and carb and seal the carb off from the engine bay?
cepx111 07-30-2007 11:57 PM
They are very fuctional peice of equipment and they really do a good job of keeping hot air out of the carb.
cool air is denser, the air in your engine compartment is hot and nasty, bad bad bad, why do you think that people spend som much time and money trying to get that cold air into the engine?
cold air makes power. Believe me I'm building one for my camaro when its done.
thetanman101 07-31-2007 05:24 PM
Yes you should still run a cleaner. It's still sucking in the dirt and bugs and whatever along with that fresh cold air.
-Tanner
