Calles Compstar or Scat 4340 crank
Which would you use in you sbc and why?Trying to keep crankshaft cost to around $500-$600
wha cha going to do with the motor ??..street cruiser, mild bracket motor, heads up balls to the wall motor, blower motor, trailer queen...this will help you answer the question if you need a $600 crank period..
Brian |
a stock good steel crank will take around 500 hsprw with a 4 blt sbc,
more power or a motor taking abuse, bjuice is right u can get a good forged crank for around $600. bucks, competition products has cola close outs for around $500 bucks for sbc :? |
i probably should have just said this yesterday but didn't...so hear goes..
My opinon is this...there are some places to cut back on a motor...but i would stay with the best parts when it comes to rotating assembly,,crank,rods,piston's.....this makes up the core of your motor..by spending a little more money and getting best parts it will open up the door for you down the road..longivity being #1... i have never MET one person that built a motor or car that DID NOT want to go faster etc...Do not make that mistake and tell yourself you will be satisfied,,cause you WILL NOT.....YOU WILL want more..SPEED/POWER is addictive..its more addictive than drugs to some of us..(hint,hint)... so do yourself a hug favor and build a solid bottom end,,so you can throw a little shot of spray on there, or make a cam or head change for some more ponies and not over rate your bottom end.. my opinion. Brian |
Re: Calles Compstar or Scat 4340 crank
But as BJ says build the short blk. to the best that your budget will allow and in the end you'll be happier. Zip. |
| All times are GMT -8. The time now is 05:33 AM. |
