bracket race cam specs for 350 chevy?
Hi, I happen to have this sbc combo and need your input on cams, 4.060 bore, 3.48 stroke, 12.7:1 to 13.05:1 compression depending on my head gasket, 4340 bottom w/ spr pistons...edelbrock vic jr intake. For heads I have ported canfield heads by mike stark of cfm performance...they started life as 200cc runners and ended up around 212...the flow numbers will be listed below. Id like a solid roller for a 2900ish lb car possibly a tad less, that weight is with driver. This engine will not see any street time, only a 1/4 mile bracket engine. Trans is a th400, I have no rear gear, converter or tire size yet as Im uncertain of what we're going to do rear suspension wise...either back half it or keep it a mini tub with a 28 ish tall slick. rpm is not a concern...I will gear and converter acordingly to match cam as well as have pro systems build a carb. Whats your reccomdation for specs ? Thanks for your help!! oh the ex numbers are without a pipe.
IN / EX 100 - 76 / 61 200 - 144 / 95 300 - 203 / 132 400 - 250 / 156 500 - 280 / 178 600 - 300 / 194 700 - 306 / 202 800 - 312 / 210 |
| All times are GMT -8. The time now is 03:59 PM. |
