-   -   tranny switch (https://www.racingjunk.com/forums/showthread.php?t=17852)
Superpro399z 07-17-2007 08:29 PM
tranny switch
I am currently using a turbo 350 in my 69 Z28, 468 bbc, dana 5.13 gears in the rear and would like to switch to a power glide. My question is will a PG bolt up without having to change any mounts? Any help would be appeciated! Thanks Mike :?:
jbsjunk 07-18-2007 04:19 AM
The 'glide will bolt right up, no issues. Of course, the converter will not swap unless the 'glide has had the input shaft swapped with a "turbo" shaft. But everything else will be fine.
Superpro399z 07-18-2007 06:22 AM
tranny
Thanks for the info jbsjunk that's what I needed to know! Any suggestions on who to deal with on a powerglide and converter? Thanks again! Mike :D
appproducts 07-18-2007 01:34 PM
MICAN, I CAN CUSTOM BUILD YOU A GLIDE AND CONVERTER FOR YOUR CAR,WHICH LOOKS GREAT BY THE WAY! I'M FROM N. FLORIDA, AND ALL I DO IS BUILD RACING GLIDES AND TORQUE CONVERTERS. I'LL BE GLAD TO TALK TO YOU AND HELP IN ANY WAY.
THANKS AND GOOD LUCK,
ALAN POPE. :D 904-845-4767
