-   -   fuel press (https://www.racingjunk.com/forums/showthread.php?t=17807)
jl4020 07-12-2007 06:30 PM
fuel press
what kind of fuel press semes low ? i have bg 280 pump and with truck runing i set my pressure at 8psi and i slowly drops to 6psi is that good or bad? what could do to fix the prolbem?
chevguy65 07-12-2007 06:52 PM
Are all your fittings tight but not over tight?
Where is your pump mounted?
What type pressure guage do you use, I have heard that most all of them fluctuate some.
Also, I am not sure but it may be normal for pressure to drop as temps come up.
jl4020 07-12-2007 06:57 PM
i think so?
pump is mounted in back of bed right next to the fuel cell
it a jeg gauge
spib 07-12-2007 07:07 PM
my fuel is set at 6.5 and stays right abought 6.5, holley blue pump, holley regulator
