-   -   Methanol Exhaust Temp (https://www.racingjunk.com/forums/showthread.php?t=17784)
jhnss396 07-10-2007 03:49 PM
:?: Can anybody tell me the ideal exhaust temperture using methanol.
davis419b 07-10-2007 04:54 PM
Done!
zipper06 07-10-2007 07:28 PM
Damn, (davis419b)
You know your sh*t, it should not exceed 1150 at anytime, preferablie between 1,000 and 1,100 as a high temp reading.
Granted you can run faster if you run leaner but you better have a sponser, because you will melt down a lot of parts at a higher temp.
my .02
jhnss396 07-11-2007 06:46 AM
I run BLP pump and 1250 carb. how much timing is good without hurting parts?
davis419b 07-11-2007 07:08 AM
Done!
jhnss396 07-11-2007 08:09 AM
I run methanol. 212 jets. 632 BB chevy. it runs in the 4.80's in the 1/8. worthy dragster.
jhnss396 07-11-2007 08:12 AM
Just got the data logger working. Just trying to fine tune.
davis419b 07-11-2007 08:23 AM
Done!
hammertime 07-11-2007 09:45 AM
I agree with Davis you have a miss in that combo, a worthy is a light car and that big motor should easily be a 4.6-7 car even with conv. heads. Shot us some more info on the combo.
The egt should be around 1150-1200 in the 1/4. I have noticed when using 2 different egt gauges/probes that it may be atleast a 100 different from the other. Just need to get close and tune from there.
jhnss396 07-11-2007 12:57 PM
632 Bodix 2x heads, 14.7 comp, 4.10 gear, 33x 16 tires, stall seems to be around 6000. Haven't run it in the 1/4 yet, will this weekend at Super Chevy at IRP.
