lunker from michigan sales motor with false info
i baught a motor from mark (lunger) that he said was a 355 sbc with keith black 10.5 to 1 pistons that he said had a fresh over haul witch was all a LIE. it was a standard bore with stock pistons and all the bearings were into the brass. MOTOR IS JUNK AND NOW HE WILL NOT RETURN CALLS OR EMAILS :x [/b]
Read the first 3 post to the scammer section and see if you can apply anything they suggest in order to get your money back....
Why didn't you pull the pan?or did you buy it without seeing it?I NEVER BUY A MOTOR WITHOUT PUTTING MY HANDS ON IT FIRST<AND THE PAN DOES COME OFF!
NOT ENOUGH INFO-------WHERE DID YOU BUY IT FROM?DID YOU PICK IT UP?DID HE SAY HOW LONG IT HAD BEEN SINCE FRESHENED UP?DID YOU HERE IT RUN? WHERE YOU WANTING YOUR MONEY BACK OR JUST WANTED IT FIXED? LOTS OF???? WE NEED MORE ANSWERS---LIVELY
| All times are GMT -8. The time now is 01:27 AM. |
