putting externally balanced flexplate on internally balanced
the flexplate i put on i noticed has a weight on it my motor and harmonic balancer are internally balanced does this matter the flexplate is a aftermarket externally balanced
i was just told to make the flex plate internally balanced just cut off the weight is this true?
Zano, You are being given alot of conflicting advise. I wuold not just cut the weight off and keep on goig. I do not agree with the way you were told to set the convertor up either. Is this a racecar or a streetcar. I have put a convertor in atleast 50 times with no problems. Let me know the answer to this ouestion and we will strat there. I have never seen a convertor with 6 lugs on it, it must be a street convertor. By the way if the flywheel is bent i wuoldnt use it anyway.
i'm glad you ask about the 6 flanges i just went and got the part # from the box go to tci.com part# 251050 shows the converter i got i never really read about it before i gave them engine spec sheet they picked it but i just looked it says 4 or 6 bolt flanges take a look if you don't believe what they say give me your email i'll send you a picture tomorrow when my boy wakes up i don't know how to send pictures . tci said that 1/8th inch gap isn't enough to worry about. when i squeezed it with my fingers i almost got the converter flush with the flexplate. the big thing is the externally balancing it will take me 6 hours to take it out no room its in a willys i'll call manufacturer on friday if i have to i'll take it out but i hope they say just cut off weight thanks zano
With GM anyway, Ive seen alot of them with 6 lug converters, most were diesels, and you can get new converters that are 6 lug, I've seen them mainly for the tractor pulling crowd. The 4 bolt they're talking about is normally Ford/Mopar.
It's TCIAUTO.com PRO-X™ 9" & 10" Race Converters The TCI® PRO-X™ 9 & 10-Inch Race Converters are designed specifically for Top Sportsman, Top Dragster and Outlaw Street Car classes. Able to handle 2500 hp plus applications (including multi-stage, nitrous assisted, supercharged and twin turbocharged engines), these high strength torque converters feature a TCI® exclusive - HDT Coating™ (Heat Dissipating Technology™) - further enhancing their ability to deliver unsurpassed consistency and durability. Features: Hand-built steel stator Forged mounting cover 3 sets of heavy-duty internal bearings Furnaced-brazed turbine and pump assembly Built for GM, Ford and Chrysler transmissions; six or four-bolt flanges and optional billet front available |
Hey Zano.Have to agree,do not just blow weights off,combined with the fact that your flexplate is bent,I would say replace it.Although I have blown weights off many 400 flywheels for 350 swaps with no issues,these were grocery-getter customers with 200hp engines that rarely saw more than 3000 rpm.Definately not advice for a race engine.Hopefully after you replace flexplate the ears will line up perfect.(they probably will)If they don`t ,we have a saying up here,"it is what it is, deal with it",meaning don`t lose sleep over it,if the converter is new, try to get a replacement.If you are STUCK with it,don`t go out & buy another one (unless you are rich) just shim the ear in question enough so you don`t put strain on the flexplate & everything is even & happy.Provided you have the correct spaceing between converter & transmission,it will not become an issue.
flywheel
Zano just get the correct flywheel and don't risk hurting the engine.
Is it worth the cost of a flywheel to risk having to fix a hurt motor? |
your absolutly right i'm picking 1 up today thanks zano
BEST RULE - STAY AWAY FROM TCI.!!!!!!!!!!!!!!!!!!!!!!!!!
| All times are GMT -8. The time now is 05:02 PM. |
