-   -   OIL Pres Question (https://www.racingjunk.com/forums/showthread.php?t=17714)
dtperformance 07-01-2007 10:22 AM
OIL Pres Question
If a sbc has 12 pounds at idle hot (700rpms 180 deg) and 30-35 cruising (14-1600 rpm) and 50 anything over 4k does this make it bad. The motor is new and yes at a idle I would agree it is low(but its a chevy)when its hot but in no way do I think the motor is hurt. as I was always told 7 psi per 1000 rpm is min and fine. The thing runs drives sounds great. Also I could turn it up to 900 and it sits at 20 at idle.
chevguy65 07-01-2007 10:24 AM
if you do not drop below probably 5 lbs at idle you should be ok.
Is it a stock oil pump?
dtperformance 07-01-2007 10:24 AM
Also if it matters it has a relocated oil filter with big bradded lines that I was told could also lower the pressure trying to puss the oil threw them big lines #6 bradded lines over 5ft each.
dtperformance 07-01-2007 10:25 AM
yes stock oil pump
chevguy65 07-01-2007 12:55 PM
I think your ok at 12lbs.
If I am wrong I know one of the guys will jump in and save the day :D
mcracecars 07-01-2007 01:10 PM
#6 braided for remote mount, is too small. Minimum should be #10
dtperformance 07-01-2007 04:38 PM
Would that cause it to be low and also it is 8 not 6 I ment #8. But still is that to small and would it cause that. Im not worried really because it runs and drives great with no prob and sounds great no noise but I had a guy come look at it to buy it and he thought it was to low and did not buy it only for that reason only. Hell I even dropped our agread price 2k right there just incase there was a prob and 2k would cover it. But its brand new and I just want other oppinions
Thanks.
lively 07-01-2007 06:37 PM
LOW OIL PRESSURE AT IDLE ON MOST CHEVIES IS NOT A PROBLEM JUST AS LONG AS 35-40 POUNDS IS ACHEIVED AT CRUISING SPEED--AND IT DOESN'T FALL OFF ABOVE THAT--MY SBF RUNS 15- 20 AT IDLE AND 40-50- AT CRUISING SPEED AND I HAVE OVER 100,000 MILES ON IT WITH NO PROBLEM--GOOD LUCK AND HOPE YOU GET IT SOLD AND IT WAS GREAT YOU WERE HONEST WITH THAT BUYER 8) :lol:
mopar1962 12-05-2008 10:02 AM
If the engines new I would definitely change the oil filter as this may be the cause of your low pressure. :!:
TheYellaBrick 01-21-2009 01:26 PM
If it's a Fram, loose it and get a Wix ! 10 lbs per 1000 RPM is a good general rule.
