Burst panel
Has any of you guys ever used the Wilson Manifolds burst panel carb spacer plates, I just ordered one should save some butterflys in the event of hitting the rev limiter.
I've got the nitrous plate by Wilson with the burst panels built in. Nice piece. Haven't had a blowout yet, so I don't know how well it works.
If you are talking about the spring-loaded panels;
IT looks like a good piece. Speed Tech Panels are the ones I use. This was their idea and Wilson must have thought it was a good one. Now Wilson offers the same idea but is using 4 bolts instead of two. If you are talking about the Wilson Burst panels or burst Windows or Burst Plugs that are replaceable like replacing freeze plugs, that idea was ok till something better showed up. About hitting the rev-limiter. Oop's not a good idea when spraying nitrous. Ed |
If you go to Wilsonmanifolds.com and click their online catalog search for part#302106 this is the one I was refering to.
That would be them, great looking engine by the way.
I run the Wilson burst panels in my car,they do work,I've tested them,LOL :P
| All times are GMT -8. The time now is 11:05 PM. |
