-   -   rocker studs backing out (https://www.racingjunk.com/forums/showthread.php?t=17638)
dragharley1 06-24-2007 05:05 PM
bbc 565 afr 345 heads , howards solid roller 685 lift ,howards 1.8 roller rockers ,10.0 to 1
the problem is ran motor twenty minutes ,,rockers started getting loud ,shut it off found number 8 exhaust rocker stud almost backed all the way out , re torqued all studs ,ran twenty more mins started happening again , my question is has anybody ever ran into this and can i just loctite them in and torque them ?
thanks in advance for help
billhendren 06-25-2007 01:10 PM
We normally use red loctite on them and torque to 65 lbs.Bill
