MUSTANG TRANNY SWAP
CAN I SWAP THE 5 SPEED OUT OF A 86 STANG WITH A 5.0 INTO A 92 STANG WITH A 5.0. THE 92 IS AN AUTOMATIC THE 86 IS COMPLETE. IF SO WILL I NEED ANY OTHER PARTS. NOT A FORD GUY AND LOST.
If you use all the stuff from the 86, should be a bolt in swap, you will have to figure out the pedal mounting.
Ron, www.gforcetransmissions.com |
THANKS!!! :D :D
| All times are GMT -8. The time now is 02:32 PM. |
