-   -   heads (https://www.racingjunk.com/forums/showthread.php?t=17597)
kiesel 06-19-2007 05:33 PM
heads
call bmf a divison of cfe. that's truly the best head on the market. My experience with the sb2.2 head is unless the power adder is flowing the head has bad qualities, or if you are turning it hard and it stays up in the rpm then it's good.
cboggs 06-20-2007 04:47 AM
Sounds like the SB2.2 experience you had was with old used nascar
stuff trying to make it work for something it wasn't built for.
A properly designed sb2.2 built for drag racing will kick butt, ..
notice all of them being run in comp, .. I have some 900+hp
engines out there with cast single 4, .. ..
Curtis
billhendren 06-20-2007 05:17 AM
I agree on the SB heads,our house 420 ci.in. super late model dirt car must pull from 4000 rpm on restarts so we cant cam them like a drag race engine.this engine makes 844 H.P. with 691 lbs torque. the same combination with a larger cam and carb makes well over 900 H.P. Bill
cboggs 06-20-2007 04:07 PM
Bill,
Are you using SB2.2's on your super late model?
Curtis
perfconn 06-21-2007 03:41 AM
Yes he is.No one uses the older SB2 stuff its not any better than the 18* stuff and stuff to fit them are very hard to find.
billhendren 06-21-2007 05:14 AM
Yes we are,the current head is a 5C Hendrick its about 6 years old with a 286 c.c. int.we also have run the 8C which has a 322 c.c. runner but was down on torque.we just got the latest 10C which is 300 c.c. with a laid back combustion chamber but haven't had the time to test it.Bill
cboggs 06-21-2007 07:11 PM
perfconn, .. yea I know the 1st gen sb2's aren't run anymore, ..
I was asking if he was running a sb2.2 or a wedge cause his post
wasn't clear in that regard.
Bill,
I've got a few hedricks sets in the shop, .. I'll have to look and see
if they are 8c, 10c etc.
Also just had a set of JGR 2007 open heads here.
Ports where very close to the open head I build, .. as well as some
of the drag / comp eliminator stuff.
Just finished a 13.5* wedge port set, ..
Brodix GB series 13.5* head.
2.2" intake 1.58" ex, 298cc intake, 2.9 csa.
lift - Int - Ex
.2 - 151.3 - 109
.3 - 226.7 - 162
.4 - 293.6 - 202
.5 - 353.8 - 241
.6 - 396.3 - 252
.7 - 416.1 - 258
.8 - 422.4 - 261
Curtis
mytmouz 06-21-2007 08:59 PM
Mind if I ask what a set of those run? :shock:
cboggs 06-21-2007 09:21 PM
$3800 bare, ..
Curtis
SVRE 06-22-2007 04:31 PM
How did you get your hands on those?
