would a set of better heads get me more power
I'm running a chevy 350 bored over .30. it has TRW 12.5 to 1 pistons, 202 solid comp cam, 1.6 roller rockers, jensen port and polished heads, edebrock vector jr. intake and 750 demon carb. What would be the best way to get more power out of this motor with out nos?
there are numerous cam selections out there..but for sure a solid ROLLER would benefit you...i DO NOT KNOW how far you wish to take this motor down or plan to buy new parts...But if you did you could make the motor a 383 stroker in place of the 355..this is 28 more cubic inches which would roughly give you 56 to 60 more hp. (2HP per ci)....you could also probably have those heads angled milled and get the compression up around 13.5 to 1....i do not know if you could get 14to1 compression or not but a good head man could tell you (Curtis)....with the compression up convert to alcohol and i would say you would pick up another 60/70 hp.....so from where you are now if you did all the above i mentioned i would not hesitate to say you could pick up another 120 to 130 hp...possibly more with the right combination.....
the type heads you have will make all the difference in the world...if you decide to go the 383 stroker route,,you might want to check into getting the 18 degree pistons along with some good 18 degree heads......going 18 degree you could make it an 800 hp motor without NOS,,NO PROBLEM. AS THEY SAY MONEY BUYS SPEED...HOW FAST DO YOU WANT TO GO ?? your post was broad if you narrow up what you are willing to do i'm sure we can give you some good info on which direction to go. Brian |
there are numerous cam selections out there.But for sure a solid ROLLER would benefit you.But if you did you could make the motor a 383 stroker in place of the 355..this is 28 more cubic inches which would roughly give you 56 to 60 more hp.Here the author is giving good thoughts and suggestions to each and every readers through this article.Quality of the content is the main element of the blog and this is the way of writing and presenting.Waiting for again wonderful blogs or posts.I found some good resources to the websites here.I am a writer at custom essay writing service,if you have any doubt n writing essays,please visit here.Visit https://www.essayguardian.com/
Absolutely—the cylinder heads will make a huge difference in the final power level. If you go with a 383 stroker, 18° pistons paired with quality 18° heads could be a serious combination. With the right cam, intake, compression, and supporting parts, an 800-hp naturally aspirated setup is definitely an ambitious but achievable goal. Great advice for anyone planning a high-performance build There’s more supabets login to than its core service, including an online casino selection for players who enjoy a change of pace. It’s a handy option for anyone looking to explore casino games online without jumping between several platforms. Be sure to check eligibility, local availability, and the applicable terms first.
| All times are GMT -8. The time now is 05:00 PM. |
