-   -   moroso vacum pump & msd crank trigger (https://www.racingjunk.com/forums/showthread.php?t=17556)
signsbyesa 06-13-2007 05:57 PM
what is the purpose of having a vacum pump as well where does
a crank trigger work with the timing, building a 496EFI and notice
some of the strong motors use the pump and a trigger, should
i consider using these and would they benefit, thanks for helping :D
SG5219 06-14-2007 04:47 AM
Re: moroso vacum pump & msd crank trigger
A vacuum pump helps greatly with crankcase ventilation to help reduce windage. They do add 15-30 hp according to some dyno figures I have read about. Less windage, more horsepower. A crank trigger all around keeps your timing where it should be. With a proper crank trigger set up I have never seen our timing vary at all. A crank trigger will not increase horsepower, but is a reliable piece to ensure your timing stays where it should be.
signsbyesa 06-14-2007 07:03 AM
lets vacum
thanks sst521mechanic
i have seen john cunningham build some strong sbc and each had
a vacum pump, i think i will add it to the 496 to keep the
motor at its best with a trigger thank again
ernest :D
