lookin for some advice alchol injection/nitrous on gas...
any one know anything about runnin blown injected alcohol and sprayin nitrous with gas...... god or bad??? can seem to find any info on this ... got a smaller blower than i would like to have and have a nitrous blower plate layin round with all the hardware... what u guys think ???
Bad Omem,
There's not a better way to burn one down than this combo. First it's almost impossibe to jet for this combo. The simplest solution, if you're looking for a little more power just add a little nitro, maybe 10% to 20%, much easier to jet and will not burn down an engine like nitrous will. Just make sure you have enough pump to push the fuel. If you run any nitro you'll need atleast an enderle 110 or a hilborn 175B #2 pump, or an enderle 990. I'm talking 9 gpm plus pumps and keep the exhaust temp. below 1400 degrees with nitro. just my opinion. Zip. |
yea just askin .lol never hurts... i got alot of experience with nitrous.. if all works out il;l have me a big blower by the middle of the weak and wont need the spray ..
Smarter idea, good luck with more blower.
Zip. |
www.alcoholinjectionsystems.com
No supercharger or turbocharger system is complete without a water methanol/alcohol injection system (most commonly referred to as alcohol injection). Whether or not you are running an intercooled system, the benefits gained from alcohol injection are so profound you simply can't afford to run without it. The best part is that these benefits can be realized in less than an hour... the time it takes to install our system. Such benefits include: Benefits of Water Alcohol/Methanol Injection: Lower air temperatures by 50-250+ degrees Reduces cylinder temperatures by 300+ degrees Increase your 87-93 pump gas by 8-20+ points Increase horsepower safely by 10-15% Allows you to safely run more boost and timing Longer more stable combustion expansion and progression Removes carbon build up from combustion chambers, pistons and valves Reduces & helps eliminate damaging engine detonation & pre-ignition No need for expensive racing fuel or additives We have the cleanest looking system, hands down!! A picture is worth a thousand words so why not take a look by clicking here. You no longer have to struggle trying to find space under the hood. Even if you're one of the fortunate few that has the space (without having to resort to drastic measures such as installing components in the fenders and bumper), we know you won't be happy with the cluttered appearance of the other guy's systems. Our trunk mount systems relocate everything in the trunk for a clean and simple install that only takes 30-45 minutes. Nobody even has to know it's there for those that want to keep it a secret!! Our trunk mount kits make it easier than ever before to install. Unlike other systems, you won't have to worry about assembling the components first and then trying to find space to install the pump, container, hoses and wiring under the hood of your ride (nearly impossible on newer vehicles). This can be time consuming (between 4-6 hours) and costly (most mechanics charge at least $100 per hour). Our trunk mount systems are typically installed in 30 - 45 minutes!! That's because our system comes pre-assembled. So the only thing you'll have to do is install the tank assembly, injection nozzle, and the fluid lines connecting the two. It's that easy! You WON"T need to remove your bumper or fabricate mounts in your fenders!! We even provide you with REAL installation instructions, not some generic steps that were haphazardly put together. And if that's not enough... give us a call. We'll do our best to help you out. Compare our trunk mount systems to the competitors systems and you'll quickly see the difference! www.alcoholinjectionsystems.com http://www.alcoholinjectionsystems.c...ted_stage2.gif |
| All times are GMT -8. The time now is 01:55 PM. |
