-   -   on 572 bbc, raising the comp from 9.7-1 to 11.7-1, hp incre (https://www.racingjunk.com/forums/showthread.php?t=17499)
badbug3 06-05-2007 09:05 PM
what would increasing the compression ratio from 9.7-1 to 11.7-1, or around 2 comp points higher, do for hp increase. Just how much difference would it make ?
billhendren 06-06-2007 05:22 AM
It would raise the torque quite a bit allowing you to use a larger cam which would add a substantial amount of power,to know the exact amount would require before and after dyno runs.Bill
