-   -   Powerglide overheating (https://www.racingjunk.com/forums/showthread.php?t=17375)
TEDKORPI 05-24-2007 10:18 AM
I am new to racing and have a powerglide that i think gets to hot. After one run its at 200 let it cool to 160 and it will go to 220 after the next run. It has a cooler on the firewall in a 2100 lb car with a 502 i have type f fluid in it is this normal or a problem. Can anyone help? THANKS
sp2816 05-24-2007 10:41 AM
The temperature does seem to be getting a little too hot (from 160 to 220 on one run), but a lot of heat build up usually comes from the torque converter slipping too much. What stall is your converter and how much does it seem to be slipping with the big block? What is the size of the cooler on the firewall? (I have mine mounted about 2" away from the firewall and it is 15x7) Make sure that the cooler isn't clogged or that the lines aren't pinched or clogged. (I run #6 steel braid line for mine) Do you have the deeper aluminum pan? This will add strength to the case and also 2 extra quarts. What size converter do you have and how long are you "on" the converter before making your run? (I don't floor my car and go onto the 2-step until the 2nd yellow goes out.)
Bill M
TEDKORPI 05-24-2007 11:49 AM
POWERGLIDE OVERHEATING
I have only made two 400 foot runs. I have a 9 inch converator that is new with 6000 stall and 7200 shift chip. I am not sure how much the converter was slipping the tires were spinning most of the way and i dont have a good feal of it yet. I let the lights come on and trans braked it less than two seconds. I have a deap pan holds about 9 quarts i think. Cooler is 15x8 with but is is mounted on the wall and i will pull it to see if it is clean. Thanks for your info. Ted
sp2816 05-24-2007 12:16 PM
6000 stall is pretty loose, so it will build a lot of heat. But with 400ft runs it still shouldn't get that hot and it doesn't sound like you are on the converter too long to build that much heat. Check to make sure that the lines aren't getting heated by a header.
I know it all goes pretty quick, especially in a new combo, but try to see what the rpm's come down to after the shift at 7200. They should come down close to the 6000 and then start pulling up again.
Good luck,
Bill M
lookingaround 05-24-2007 12:35 PM
id try moving the cooler out in front of the radiator so it can get cooler air.instead of all the heat in the motor compartment.jmo
