-   -   jw trans burnt up band (https://www.racingjunk.com/forums/showthread.php?t=17330)
racevega 05-19-2007 05:47 PM
what would cause a new band to burn up on 4 passes
fishman1 05-19-2007 07:25 PM
to loose band maybe
racevega 05-19-2007 07:29 PM
adjusted band to spec
sp2816 05-19-2007 07:42 PM
The servo piston could be leaking pressure and not applying fully or in high gear it might not be releasing fully. In low gear, fluid is pushed against the servo to apply the band, but when you shift into high gear, the fluid applies the clutches but it also pushes on the inside of the servo to release the band.
You could have low fluid pressue due to internal leaks (sealing rings on front pump tower to clutch drum) or a weak front pump. I recommend the dual O ring servo and the Kevlar band. These items really helped the life of my powerglide.
Bill M
racevega 05-19-2007 07:52 PM
it has a dual oring servo and the sealing rings on the pump are new and looked good when i took it out.rev and second work great
sp2816 05-19-2007 08:47 PM
Make sure that there isn't a crack in the servo bore allowing it to leak or a problem with the tube from the valve body to the case. If the surface wasn't good on the clutch drum, it could cause it to not hold. I drill holes in the drum under the band to help lubricate it, sounds like yours might already have them.
You didn't state if it was a stock band or an aftermarket. I have heard that you don't want to clean the aftermarket ones in parts cleaner.
The other thing would be that the linkage arm hole matches the shifter being used. I changed from a B&M to a QuarterPro and had to buy the different lever, because I could never get it to pull in 1st correctly after lining it up for neutral.
One of the last things that I can think of would be a problem with the valve body. Some times the valve bodies don't use gaskets at all and they can cross leak. Make sure that if it has the gaskets that they are the correct ones and don't cover any holes in the plate. There are a couple of gaskets that don't cover all of the valve body, so there can be a leak with them.
Just some more thoughts.
Good luck,
Bill
mytmouz 05-20-2007 06:38 PM
I had the problem sp2816 described also. Would work fine around the shop after repairing, but would toast it under a load.
